Fiets is nog vrij standaard heb alleen stuur vervangen voor een Renthal Fatbar.
HPC Carbon Monocoque Advanced Twin Mold Technology, Aluminum 6061 T6 Rear Triangle, ATG, ETC 4-Link, AXH
COLOR
carbon´n´red
SIZE
27.5: 16", 18", 20" // 29er: 19", 21", 23"
FORK
Fox 32 Float Factory FIT4, Open(Adjustable)/Medium/Firm Mode, Tapered, 15QR, 120mm, Kashima Coated
SHOCK
Fox Float DPS Factory, 184x44mm, Open(Adjustable)/Medium/Firm Mode, LV Air Canister, Kashima Coated
SHOCK HARDWARE
Top: 30x8mm, Bottom: 22x8mm
HEADSET
FSA Orbit I-t, Integrated, Top 1 1/8", Bottom 1 1/2"
STEM
CUBE Performance Stem Pro, 31.8mm
HANDLEBAR
CUBE Rise Trail Bar Pro Carbon, 750mm
GRIPS
CUBE Race Grip, 1-Clamp
REAR DERAILLEUR
Shimano XT RD-M8000-DSGS, ShadowPlus, 11-Speed, Direct Mount
FRONT DERAILLEUR
Shimano XT FD-M8020-D, Direct Mount, Side Swing
SHIFTERS
Shimano XT SL-M8000-I, Direct Attach
BRAKE SYSTEM
Shimano XT BR-M8000, Hydr. Disc Brake (180/180)
CRANKSET
Shimano XT FC-M8000, 27.5": 36x26T // 29": 34x24T, 175mm (180mm for 23" frame size)
CASSETTE
Shimano XT CS-M8000, 11-42T
CHAIN
Shimano CN-HG601-11
WHEELSET
DT CSW MA 3.7/3.9 Straightpull Wheelset, 28/28 Spokes, 15mm / X12, Tubeless Ready, DT Swiss Pro Head® Reinforcement System, Squorx® Alloy Nipples
TIRES
Schwalbe Nobby Nic Kevlar 2.25, LiteSkin
SADDLE
Selle Italia SC1
SEAT POST
CUBE Dropper Post, Handlebar Lever, Internal Cable Routing, 31.6mm, 458x150mm (400x120mm for smallest frame size)
SEATCLAMP
CUBE Screwlock, 34.9mm
WEIGHT
12.3 kg
