Bij deze mijn nieuwe glimmende epic!
Na de verkoop van mijn focus black raider 2007 stond deze eigenlijk direct klaar
Alleen een beetje jammer van het weer
Specs:
FRAME Epic FSR M5 alloy, fully manipulated frame w/ ORE DT/TT, sealed cartridge bearings, 100mm travel, replaceable derailleur hanger
ACHTERVERING Specialized AFR remote mini , BRAIN inertia valve w/ BRAIN fade and rebound adj.
VORK Fox F100 RL, 100mm travel, air spring, compression and rebound adj. w/ LO, alloy steerer
BALHOOFDSTEL 1-1/8" Threadless, 10mm insertion alloy cups, sealed cartridge bearing
STUURNOK Specialized adjustable rise, 31.8mm clamp, 3D forged w/ CNC finish
STUUR Specialized XC low rise 31.8mm bar, 6066 butted alloy, 6 degree up, 8 degree backsweep, 640mm wide
HANDVATEN Specialized thin lock on grip (S/M) Specialized Thick lock on grip (L/XL)
VOORREM Custom Avid Elixir R SL, alloy backed organic pads, S/M: 160mm, L/XL: 185mm rotor
ACHTERREM Custom Avid Elixir R SL, alloy backed organic pads, S/M: 140mm, L/XL: 160mm rotor
REMHENDELS Custom Avid Elixir R Carbon SL Hydraulic, tool-less adj. reach
VOORDERAILLEUR Shimano M660 SLX, DMD, top swing, dual pull
ACHTERDERAILLEUR SRAM X-9, 9-speed, mid cage
SCHAKELHENDELS SRAM X-7, aluminum 9-speed trigger
CASSETTE Shimano HG61, 9-speed, 11-34t
KETTING SRAM PC-971, 9-speed w/Power Link
CRANKSTEL Custom Shimano FC-M542, S: 170mm, others: 175mm
TANDWIELEN 22S x 32A x 44A, 4-bolt, 104/64mm
TRAP-AS Shimano FC-M542
PEDALEN Shimano M520, clipless
VELGEN Custom DT Swiss X420SL, 24mm w/ eyelets, 28/32h
VOORNAAF Specialized Hi Lo disc, CNC flange, sealed cartridge bearing, 9mm DT RWS, alloy QR, 28h
ACHTERNAAF Custom Shimano M525 SL, alloy QR, 32h
SPAKEN DT Swiss 1.8mm stainless, black, alloy nipples
VOORBAND S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
ACHTERBAND S-Works Fast Trak LK, 26x2.0", 120 TPI, tubeless ready aramid bead, dual compound
INNER TUBES Specialized Ultralight 26x2.0", presta
ZADEL Specialized Phenom, hollow Cr-Mo rails, thin foam, S/M: 130mm, L/XL: 143mm
SEATPOST 2014 butted alloy, single-bolt setback, S/M: 350, L/XL: 400mm
ZADELPENKLEM 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
Gewicht 12.66 incl. pedalen
Specialized Epic Comp 2009 / Myka Pro 2010 [Update P5]
- Mijn mountainbike: stumpjumer 29er custom
Laatst gewijzigd door Peetooorrrr op vr 26 februari 2010, 02:24, 3 keer totaal gewijzigd.
- Mijn mountainbike: Scott Scale 10, Trek 8500
Erg vette bike! Maar waarom geen specialized vork?
- Mijn mountainbike: Tomac Supermatic 120mm, FOX, Tr!ckstuff, FRM, Aerozine, Sram XO 10 Speed, ZTR crest
Erg mooie bike, ik vind die fox er ook wel erg mooi in hangen
Hoofdsponsor: Tomac / Bikecustomizer
Ik neem dit jaar deel aan de jubileum editie van Duchenne Heroes.
Volg mij weg naar €10.000 voor Duchenne via:
http://www.mtb4duchenne.nl" onclick="window.open(this.href);return false; , http://www.twitter.com/mtb4duchenne" onclick="window.open(this.href);return false; of http://ferdi4duchenneheroes.hyves.nl/" onclick="window.open(this.href);return false;
- Mijn mountainbike: SC Blur LTc & Salsa El Mariachi
Omdat de Comp lijn standaard niet wordt geleverd met een Future Shock, maar met een Fox. Daarnaast is de introductie van de Future Shock dempers en vorken niet helemaal vlekkeloos verlopen, weet dus niet of de TS hier nou zo rouwig om moet zijn...Farmerboy Ruud schreef:Maar waarom geen specialized vork?
Work... the eight hours between bicycle rides.
Valuta kwestie uiteraard. En het feit dat deze er al onder zatFarmerboy Ruud schreef:Erg vette bike! Maar waarom geen specialized vork?
Ik zou ook blijer zijn met een Fox dan een Futureshock.
Wel een grote fiets, een XL?
Veel plezier ermee !!
Ciao
Jan
Ciao
Jan
Yes mijn ellendig lange lichaam moet wel goed kunnen zitten
- speedrider
Alweer zo'n prachtig apparaat waar ik zelf ook op fiets . Hier ga je nog heel veel plezier aan beleven
Life is short.....................enjoy it!!!
ik ben 197cm lang
Vandaag mijn eerste rit erop gemaakt! En ik sta versteld niet normaal hoe hard je kan afdalen met zo'n ding .
Ik betrap mezelf er alleen wel op dat ik juist alle hobbeltjes op aan het zoeken ben
- Mijn mountainbike: Trek Fuel EX8 Eagle
verkeerde smiley joh...
Peetooorrrr schreef:Vandaag mijn eerste rit erop gemaakt! En ik sta versteld niet normaal hoe hard je kan afdalen met zo'n ding .
Gisteren werd er paniek gezaaid , vandaag stond het al een meter hoog
wielrennert
Trek Fuel EX8 Eagle
wielrennert
Trek Fuel EX8 Eagle
