Roval Traverse Fattie 38 27.5 148
janepic
Item: Roval Traverse Fattie 38 27.5 148
Plaats: Lelystad/NL
Staat: ZGAN, kaarsrecht
Reden van verkoop: Roval Traverse 29 fattie
Prijs: e.275.00 excl verzend. nw prijs e.599.00
incl zgan fast track 27.5x2.8 banden.
zonder cassette of schijven
specs
Rim Material: E5 high-strength alloy
Rim Width: 38mm internal
Front Spoke Pattern: Two-cross
Rear Spoke Pattern: Two-cross
Spoke Count: 28h Front, 28h Rear
Spoke Type: DT Swiss Competition Race J-bend
Nipple Type: DT Swiss Brass Pro Lock hexagonal
Front Hub: Alloy body, 15mmx110 thru-axle, 19 and 31mm OD
Rear Hub: CNC-machined alloy body, high-quality DT 360 internals, includes shimano freehub
Bearing Type: Sealed cartridge
Roval Engineered J-bend hubshells have a single spoke length for each wheelset.
Assembly Method: Hand-built
Every wheel includes tubeless valve stems in order to make tubeless set-up a touch easier.
Total Wheelset Weight: 2000g
